Best plywood
Best plywood
Postby seanpg13 » Sat Jul 30, 2011 7:46 am
I am thinking about about building a Weekender or a Long Weekender and I want to Know What plywood is best?
I was probably going to Use Marine Fir at least for the bottom and exterior. I was just going to seal it with marine epoxy and boat paint or one of the other sealers.
Is osb good to use? It is used in the weekender build photos. It looks heavy.
Also what about the new green plywood?
Also How should I seal the interior to stop formaldehyde vapors? I saw about Katrina trailers having vapor issues on the news.
I also thought I might buy a used boat trailer on ebay or craigs list to start the trailer on. Any thoughts. :thinking:
thanks Sean from Texas
seanpg13
Postby doug hodder » Sat Jul 30, 2011 1:29 pm
It kinda depends on your budget. Marine grade ply is wonderful stuff, but in my opinion, isn't necessary. It's pricey. I only use the thin marine stuff to skin over regular ply on a woody as I buy the mahogany stuff.
Baltic birch is great as well, but only comes in typically 5x5 sheets, so it needs to be joined. It paints up great and has tons of laminates in it so it is really stable. It's made for cabinet construction. I use a lot of it in my builds available at regular type "lumber" yards, not a big box item. It's also more expensive
Another option is MDO. It is a sign industry type ply, made for exterior uses and can be had with 1 or 2 sided laminate that takes paint great. I've used it with good results. They don't sell a lot of it so it's usually really dry. It's not sold at big box stores. Gotta go find it.
I know that Bob Henry has used OSB on his builds with decent results. I haven't done that so can't really be of help there.
Watch any "green" ply as it will want to do strange things as the moisture content drops. You might find yourself fighting warped ply and that's a real drag around the door areas. I do use it for my floor. I've done tears using the big box ply for sides, but laminated a nice birch skin for the interior and either skin in aluminum, or do epoxy and paint on the exterior.
On any of your ply, don't leave it sitting against a garage wall for storage as it will want to cup. Try to leave it flat until you get it cut into smaller pieces. If you have to leave it vertical, try to clamp it to something so that it doesn't do that. Once you cut your doors, lay them flat for sure, don't lean them. Ask me how I know this.....
I'd imagine that you'd only have outgassing problems on something like an OSB/ particle board/ MDF situation, but I'm no expert on that.
Just my opinions. Doug
Postby Shadow Catcher » Sat Jul 30, 2011 7:59 pm
Marine grade is the best no voids and glues resistant to moisture. OSB is actuall slightly more resistant to moisture than conventional plywood but no where as good as marine grade plywood.
Postby Sam I am » Sat Jul 30, 2011 10:05 pm
I used Baltic birch on my tear with good results. It takes any kind of finish and fasteners well, and stays flat. I used some scraps of it for some other projects around the house, and it works well.
Sam I am
Images: 106
Postby seanpg13 » Sat Jul 30, 2011 11:00 pm
:thumbsup: Thanks I hope to start soon
Sean
seanpg13
Postby aggie79 » Mon Aug 01, 2011 9:59 am
Sean,
I don't know what part of DFW you're in, but if you are on the Fort Worth side, there is a company in northeast Fort Worth that has a great selection of plywoods. They sell to individuals as well as cabinet shops. I used their Russian Birch which is a close approximation to Baltic Birch for the plywood skins for my insulated sidewall and floors. This is their website:
http://www.plywoodcompany.com/application/home/main.aspx
Their are some other specialty plywood places in Irving, Dallas, and Richardson, if these are close to you.
Take care,
