Build/Seal a Flat Galley Hatch for Grasshopper Type Trailer
Postby stu_stumble » Wed Oct 19, 2011 8:08 pm
Hello All. I am going to be building a Grasshopper type trailer and am having some issues with how to build the hatch for the galley. It will be on a 5x8 Northern Tool Frame. I will not be stretching the plywood so the dimensions of the actual trailer will be just a typical 5 foot wide by 8 foot long.
Well I better get to the point here. I was thinking I am basically going to have the hatch be a flat hatch like the original Grasshoppers were designed. No roof involved in the hatch. I was just wondering about your thoughts on the actual hatches construction.
I was thinking that I would just frame out the hatch as you would for a Benroy or others except it would be flat and no curve. Figured then cover it in 1/4 ply as this is what I will use for the roof outer skin.
As far as sealing the hatch would go I was thinking about just using T molding with weather seal that would lay against the body of the trailer and be tightened down when I would crank down on the hatch handle. OR I could build a lip inside the hatch and line this with weather seal to press against the hatch lid when it is closed.
I am new at this and so my ideas may be awkward at best and I would appreciate any help on this. If you have pictures of how you have done it or would do it that would be great.
Again I really appreciate all of the help I am receiving on this forum. You all are such great people.
Haze Gray and Underway!!!!
Anchors Aweigh Me Boys.
stu_stumble
Images: 7
Postby Sonoma ZR2 » Wed Oct 19, 2011 8:28 pm
One way you could go about a flat hatch is to buy a compartment door from a RV surplus dealer such as. http://stores.ebay.com/Bottom-Dollar-Surplus-Inc Here is a Cargo door 49" x 25" x 2" it has a lock and key ready to screw in. 260874575148
Sonoma ZR2
Images: 90
Postby bobhenry » Thu Oct 20, 2011 7:00 am
Here ya go stu
Joanne has done a great job of documentation of her entire grasshopper style build. I used it as a guide for the very detailed electrical schematics and pictorials on my teardrop build. You might want to browse thru front to back it may save you some OH S$%^T moments.
http://www.asolidfoundation.com/
"Building the shell part 3" is the start of framing the hatch!
Thanks
Postby stu_stumble » Thu Oct 20, 2011 8:01 am
Thanks Sonoma and thanks Bobhenry. Both of your ideas are great. I really appreciate the help. You guys are awesome. I was looking at Joanne's electrical schematics for a DC system and they are a great help. I will be sure to check out the rest of her build for ideas. thanks again. :thumbsup:
stu_stumble
Images: 7
Postby mallymal » Thu Oct 20, 2011 5:21 pm
Sonoma ZR2 wrote:One way you could go about a flat hatch is to buy a compartment door from a RV surplus dealer such as. http://stores.ebay.com/Bottom-Dollar-Surplus-Inc Here is a Cargo door 49" x 25" x 2" it has a lock and key ready to screw in. 260874575148
Wow! and check out the prices of windows too.....pity I dont live a little closer :lol:
mallymal
Images: 18
