Brass Water Inlet or Outlet
Postby bdosborn » Sun Mar 05, 2006 10:05 pm
I made a new water outlet today out of brass parts. I had a plastic part that I used to drain the sink and it stripped when I connected the grey water hose to it. Hopefull this one won't. Its made from a 3/4" hose barb to 3/4" male hose adapter. I should have used a thicker piece of brass for the plate but it will work. I'm thinking this would be a cheap water filler if you used a female hose adapter. This will be on the bottom of my trailer so I didn't bother to clean it up. Total cost - $5.56.
Images: 806
Postby 48Rob » Mon Mar 06, 2006 8:15 am
Bruce,
Good thinking! :thumbsup:
Bet it lasts a lifetime.
Rob
48Rob
Postby bdosborn » Mon Mar 06, 2006 11:15 am
Thanks Rob. I'll let you know how it works.
Images: 806
