1/2 inch baltic birch
Postby wingrydr57 » Sat Jan 28, 2012 12:11 pm
I would like to build a 4x8 Benroy from the free plans here on this web page. To try to keep it as light as possible could I use 1/2 inch baltic birch plywood for the sides? I would also make all the cabinets out of pine to help keep weight down.
Thanks to all, Steve W.
wingrydr57
Postby Woodbutcher » Sat Jan 28, 2012 5:10 pm
Sure you can. Baltic birch in half inch may weigh about the same as cabinet grade 3/4" plywood because it is a hardwood core and more dense. It is better stuff but if weight is an issue I would look into that. My current build is using a sturdy frame made out of soft maple. It's strong and light weight and I will skin it with 1/4". Then a woody frame on the outside also out of soft maple.
Here is what I'm talking about...
All the interior shelves and dividers are 1/4" also.
Don't know if this helps or confuses you. :lol: But have fun with your build!
Woodbutcher
Postby wingrydr57 » Sat Jan 28, 2012 5:20 pm
Woodbutcher wrote:Sure you can. Baltic birch in half inch may weigh about the same as cabinet grade 3/4" plywood because it is a hardwood core and more dense. It is better stuff but if weight is an issue I would look into that. My current build is using a sturdy frame made out of soft maple. It's strong and light weight and I will skin it with 1/4". Then a woody frame on the outside also out of soft maple.
THank you very much for the tips! Lots to think about here.
Clear skies, Steve
wingrydr57
Postby doug hodder » Sat Jan 28, 2012 5:56 pm
True baltic birch only comes in 5x5 sheets...for the sides, you're gonna have to splice it. A 4x8 sheet of material would take care of that, and would be less $$. Doug
Postby halfdome, Danny » Sat Jan 28, 2012 6:44 pm
Check around in your area where you get your Baltic Birch plywood as I have purchased it in the past in 4' x 8' sheets at Crosscut Hardwoods in Seattle.
Also look for Apple plywood as it is very similar to Baltic Birch and comes in 4' x 8' sheets.
Baltic Birch & Apple can be warped so select your sheets with care. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
