Can I get this material anywhere?
S. Heisley wrote:If you are talking about the wood doors in really old houses, some of that was actual wood boards, joined, like a really good table top, not plywood or MDF or plywood veneer or whatever. They don't make 'em like that anymore. I would think that you could do something similar with dry, flat plywood. Once you get several layers of primer and glossy paint on them, I doubt most people would know the difference.
deceiver wrote:Get some wood and find someone with a planer. A lot of home shops have them. It takes about 15 min to take it down to 3/8 inch from 3/4 and leaves a smooth finish. Most home shop planers though will only plane 12" wide so hopefully your door is that size or less.
