I have two questions:
1. What kind of rivets should I use so the whole thing is watertight?
2. Any other solution to this? :-)
LDK wrote:Thats a good solution you came up with using the 1/8" flat aluminum and then putting angle aluminum over it. I also used rivets too. I think it was 3/16" but not sure. It would also be a good idea to use a good quality adhesive/sealant under the alum and maybe a dab in the rivet holes. Good luck!
