As I am still in the design stage of a lightweight TD, I do have a question:
The roof will be 3 mm (1/8") outside and inside, and insulated. Trailer will be 4' wide. However, I'm still undecided about the roof 'thickness': I believe 2" height for the spars is quite common, but does anyone have experience with less? Is 38 mm (1 1/2") still acceptable? How about even less than that? Structurally, the thicker the better, I know... I don't expect to go and sit on the roof
Willem
