1/2" Walls
1/2" Walls
Postby webbaldo » Wed Aug 15, 2012 6:08 am
I thought someone may have posted something similar but im struggling to find anything in the search,
anyway,
After alot of thinking, im pretty sure im gonna go for 1/2" plywood walls to keep the weight down. Im insulating the roof but not bothering with the walls anymore. To keep weight down i'd prefer to use 12mm (1/2) ply with alu skin instead.
My main question is, would this be enough meat to screw items such as the door piano hinges too etc?
Im not bothered too much about the thickness for the roof edge fitting as im using Aggie's awesome idea of one continuous nailer block from plywood. So in reality for the roof edge ill have the 1/2" wall + 3/4" nailer block
Im just concerned about other items like the doors. And also finding t moulding for the doors which is 1/2 and not 5/8
What are your views?
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Re: 1/2" Walls
Postby kirkman » Wed Aug 15, 2012 10:01 am
My tear is 1/2". No problem attaching any thing! :thumbsup:
kirkman
Images: 55
Re: 1/2" Walls
Postby len19070 » Wed Aug 15, 2012 5:06 pm
Web.
I have built numerous trailers with 1/2" plywood sides.
BUT!
Don't think it can't be done without insulating???
I glue a "Foam backed Rug" to the inside of my Tears.
Now..whats the "R" value of a "Foam Backed Rug"?? Not a clue!
But whats the "R" value of a sweatshirt...a blanket or a wool coat? Don't know that either.
But they all work! Some things are just not assigned an "R" value because there not associated with insulating.
Covering the inside walls with rug does insulate, makes a nice interior finish, makes it quiet and is an option.
And "Kills 2 Birds with One stone"
Happy Trails
Len
len19070
Images: 24
Re: 1/2" Walls
Postby eamarquardt » Wed Aug 15, 2012 6:41 pm
If you use 3/8" (or even 1/8" or 1/4") on the outside, 1" spacers, and 1/8" on the inside you can use 1" foam to insulate it, the weight gain will be marginal, the stiffness will increase significantly, and you'll have 1 1/2" (or so) of "meat" to attach to. Far "betterer" IMHO.
Cheers,
Gus
eamarquardt
Images: 150
Re: 1/2" Walls
Postby webbaldo » Thu Aug 16, 2012 5:45 am
thanks for the replies guys
webbaldo
