After three coats of Rustoleum with a 4" foam roller, I still have a few dull spots on my weekender. Not sure what causes it, but I tried every which way to avoid it to no avail. Rolled heavy, rolled light, rolled hard, rolled soft, rolled crossways, etc. I'm not shooting for a pristine glossy carlike finish, but I would like to have the paint with a uniform gloss throughout if possible. I've seen the Youtube video on how the guy does get a carlike finish with wet sanding, thinning, rubbing, etc., but I'm simply not going to put that much work into it (might as well set up a spray booth).
Has anyone used rubbing compound and hand or machine buffing to bring out the shine in Rustoleum or any similar oil based paint? I assume that you need to wait a few weeks for it to cure out pretty hard.
