skinning a roof poll. slows new teardrop 2 time around.
Re: skinning a roof poll. slows new teardrop 2 time around.
Postby ssrjim » Sat Sep 01, 2012 10:18 am
Aluminum
93079
ssrjim
Postby NathanL » Sat Sep 01, 2012 8:42 pm
I have done plywood and plywood covered with aluminum. Some people do aluminum by itself but I'm not a fan of that due to low puncture and major ding/dent resistance if you camp where stuff falls out of trees, the wind blows stuff around a lot, or even stuff on the road hitting your trailer.
NathanL
Postby Lgboro » Sun Sep 02, 2012 3:29 pm
Aluminum over foam.
Lgboro
Images: 53
Postby len19070 » Sun Sep 02, 2012 5:24 pm
Aluminum over 1/8" Masonite.
Or
EPDM Rubber over Masonite.
Happy Trails
Len
len19070
Images: 24
Postby Boodro » Sun Sep 02, 2012 11:17 pm
FRP over 1/8 inch masonite 7 years ago no issues
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby Rhino Ray » Mon Sep 03, 2012 8:59 am
Aluminum over Baltic Birch.
The eleventh commandment: Ye that snoozeth loozeth. Selling real estate in ALL of Jefferson State (Northern California and Southern Oregon)
My Build http://www.tnttt.com/viewtopic.php?f=21&t=49746
Rhino Ray
Images: 60
Postby rowerwet » Mon Sep 17, 2012 8:06 pm
paint impregnated canvas over 1/4" luan, bent the luan using ratcheting straps, it helped that I built my tear outside during a very wet spring, it made all my lumber nice and flexible. the porch and floor paint finish is nice and tough, didn't even show wear from carrying my kayak on the roof for 1,400 miles.
rowerwet
Images: 521
Postby Sam I am » Mon Sep 17, 2012 8:56 pm
I used two layers of 1/8" thick Baltic birch plywood. It just falls around the curves. First layer is screwed to the spars, and the second layer is glued over the first, staggering the seams. It has held up well for six years.
Sam I am
Images: 106
Postby Rhino Ray » Mon Sep 17, 2012 11:34 pm
The Baltic birch comes in 5X5 sheets 1/8 thick and is easy to curve naturally. That's why using two sheets glued together is very effective. I only used one sheet and then aluminum because I had a layer of insulation under it giving it stability.
Rhino Ray
Images: 60
Postby Woodbutcher » Tue Sep 18, 2012 6:59 am
I used Marine vinyl over Baltic Birch that had 2 coats of epoxy as a sealer. No insulation.
Woodbutcher
Postby Oldragbaggers » Tue Sep 18, 2012 7:06 am
I used one layer of 1/8" baltic birch fastened on with staples and PL Premium. It has 2 layers of 12 oz fiberglass cloth over it. (Was only supposed to be one layer of fiberglass but I had problems with the first layer so I ended up with 2.)
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby grant whipp » Tue Sep 18, 2012 4:19 pm
.040" aluminum sheet over 1/8" luan or baltic birch (grain run side-to-side to make the bends easier) with foam board insulation between the roof beams ... has been my standard for over 25 years and never a problem!
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
