Paul Cook
Las Cruces, NM
Paul wrote:I'm still a long way from starting any construction, but I want a footwell in my tear when I finally get around to building it. Do most people have some tubing welded to the chassis to help support the footwell or do you just build a box that hangs down below the chassis? I've searched through several threads on footwells, but I'm having trouble finding the details to answer my question. Also, if I decide to go with a torsion axle instead of leaf springs, how does this affect how the axle needs to be setup as far as ride height? I don't ever plan on doing any offroading, but I might go on a few bumpy roads now and then. I plan on building an 8ft long by 5ft wide tear with a profile similar to JPLOCK's Windsong. I figure the footwell needs to be about 2ft front to back and 3ft wide. That will give me a nice size table with some space between the edges of the table and the doors for getting in and out. Any thoughts?![]()
Paul Cook
Las Cruces, NM
prohandyman wrote:Help me understand something about footwells - where does the mattress go while you are using the footwell?
Paul wrote:Thank you all for the pictures and advice.
Danny, if you had it to do over again would you still insulate the footwell? I'm thinking of insulating mine when I build it, but if I don't really need it, why bother. With the rest of the tear insulated and the floor back in place while you're sleeping, I'm not sure the insulation in the footwell would be necessary. By the way, nice tear![]()
Again, thank you all for the pictures and advice. I'm feeling a lot better about this now.I was almost thinking of leaving the foot well out because I was afraid it would make things too complicated, but I really want to have one.
Paul
Paul wrote:Believe it or not, I forgot one question in all of that. The way I'm planning this, I should have a foot and a half of sitting space on either side of the footwell. I realize this might be a little tight, but does that seem workable? Or should I put all of the sitting space on one side of the footwell and forget about having anyone sitting on the opposite side of the table?
Paul
