BrianB
Posted: Fri Feb 04, 2005 3:27 pm Post subject:
I was using the V=Pi*R2h formula. Using that, there should be 2412.75 cubic inches in a 4"x4' tube. With a gallon of water taking up 231 cubic inches, it works itself out to about 10 gallons.
Then again, I liked Geometry in school so much I took it twice.
Thanks for the compliment, Dave. I call it "ode to Roly."
Ira wrote:I did the math, and you need 3 million feet of 3" pipe to hold 3 quarts.
But let me double check that--I may have accidentlaly moved a decimal point.
I get the same number as you did - 5 gallons of water would out an extra 30 pounds ot so on the roof of a tear . . . . not the best thing for the center of gravity - Not to mention that the 217' of copper pipe would probably weigh another 50 or 60 poundsdovaka wrote:i believe it works out to 5.3 cubic inches per foot of pipe and there are 231 cubic inches of water per gallon making each gallon use 43.5' of pipe and 5 gallons would be 217'
Keith B wrote:Actually, if you consider the heat in KS, the teardrop itself gets pretty hot during the day, so if you have good rubber on the windows and doors you could just stick a hose in the fantastic fan and fill the entire TD for a nice big hot water supply....hmmm, lets see, a 5' TD w/ 8' of interior (bed) space....this is of course if the interior is "round" inside... consider not everything is square I'll just assume it's more round than straight![]()
3.14x900x8x12=271296.00/231=1174.44 gallons... that outa do it.
Alphacarina wrote:dovaka wrote:A plastic 'Solar Shower' bag makes lots more sense - I've used those on sailboats too and they heat water pretty quickly and are the original 'member' of the 'K.I.S.S' club![]()
Don
teachu wrote:http://www.watertanks.com/calc.asp
