www.flickr.com/dantechfab
www.geocities.com/dantechfab
Airspeed wrote:I used the indoor outdoor carpet stuff, it was a waste of time in the long run, it did help initially, holding the side panels in place while I applied them but after about a month I could tell it let go it grasp.
I struggled with the decision to use glue for a long time and should have taken the advise not to waste my time on it. all the trim holds mine in place and the .040 aluminum lays flat and smooth.
I can honestly say that glue is not necessary!
Aaron
Airspeed wrote:I have never seen my "oil can" is that a common problem? I would think the air under the skin would easily find an exit, could your aluminum itself just be expanding? I applied mine on a hot day, maybe it was in full expansion when I applied it and therefor is somewhat stretched?
Might be something to consider! I think I actualy considered the temp when I applied it. Aaron
SteveH wrote:I used contact cement as recommended by an old pro, and it has been on now for four years without the first "oil can". It's not easy to do, but the procedure is to first seal the wood (I used polyurethane), clean the aluminum well, apply the glue to both the aluminum and the wood, and then install the aluminum. That's the way they were built in "the old days".
You do need to install the aluminum on a warm day with the aluminum having been in the sun for a while.
I've been in lots of hot weather, and some cool weather, with no problems.
