kenaum wrote:Dee:
I have been following your project with interest due to the fact I also would like to build a 5ft. tear on the HF trailer.
If you could clarify something, I would greatly appreciate it ! In your posts you mention that you are building the deck with 2x4's on edge and 1/2 plywood.....thus giving enough clearance to clear the tires......but in your photos it apears that the 2x4 side rail is directly over the tire, thus giving almost no clearance at all. Then after going over your notes, you mention that the deck overhangs the frame by 7" each side.......does this put the 2x4 side rails outboard of the tires ?
Sorry for the confusion !!!!!!!!!!
Thanks for the interest, and questions.
The 2X4 frame obviously adds weight, but I feel this 2X4 frame is necessary since I am extending over the steel side rails of the trailer frame.
The simple answer to your questions is Yes, the 2X 4 on the side of the deck is outboard of the tires. The phot posted so far is misleading. I'll try to post a better one.
Here is the more complete answer, however. . .
I used a 1X 4 as a band board to support the outside of the deck. This is the same dimension as the framing that I am using for my side wall. The wall will be lag bolted into the deck cross members. So, the width of wall pluss tyhe width of the band board comes up to 2X 4. When I get to this stage of the final assembly, the wall will be "glued and screwed" to the band board sides of the deck.
I have read the opinions about this kind of construction. The point can be made that it is weaker than having the wall sit on top of the deck. I see and undertand the point. I opted for this approach, time will tel if it is a mistake... I consulted with a contractor about the weight of my walls and roof, the effect of this mass being pounded by road bumps, and the ability of the 2X4 to support the dynamic load. Although he is not an engineer, in his practical experience of building he thought I would be OK. We also talked about the shear strength needed for this construction. He did some calculations and recommended I use 1/4# diameter 4" long stainless steel lag bolts with a hex head instead of screws. I will use 10 of these, 5 per side. Each lag hole will be pre drilled. Check in after a year or so and I'll be able to tell you if this was wise or not.
In addition I will be placing a 1X 3" wood cleat along the base of the wall on the deck inside the trailer. The cleat will be anchored into the wall framing members as well as intothe deck surface. The cleat will help to bear the weight was well, but the total capacity is fingured into the lag bolts I'll use.
This may be more than you wanted to know, but I hope it helps.
DEE
I hope to post a picture of this later to make it more clear.
Grace happens...
