DOORS ?
DOORS ?
Postby thewhinge » Thu Jul 16, 2009 1:40 pm
I Have noticed nearly all teardrops havetheir doors openening towards the front, is there a reason for this?, i did want my door to follow the shape of the curve of the front ie open towards the rear, any advice would be gratefully appreciated.
:thinking:
thewhinge
Images: 24
Postby cokebottle10 » Thu Jul 16, 2009 1:49 pm
Door closed but not latched + 70 mph down the highway + Wind catches door = Doorless trailer.
:cry:
David
cokebottle10
Re: DOORS ?
Postby rbeemer » Thu Jul 16, 2009 1:50 pm
The Whinge wrote:I Have noticed nearly all teardrops havetheir doors openening towards the front, is there a reason for this?, i did want my door to follow the shape of the curve of the front ie open towards the rear, any advice would be gratefully appreciated.
:thinking:
AHHH, suicide doors. It is a personal preference but the one risk of these type of doors is that if you are traveling down the road and your door comes open the wind could slam the door against your tear and cause damage to the side and possibly the door.
Rick
If ducks had scales, would fish quack?
rbeemer
Postby bobhenry » Thu Jul 16, 2009 1:59 pm
It's your project do it your way !
I didn't have one of mine latched and when I stopped it swung forward and hit a clearance light I had to replace window in the door and a clearance light lense. So it can happen either way. End lesson latch the darn doors and you are good to go.
Postby jackdaw » Thu Jul 16, 2009 5:51 pm
Just to add my two pennys to the pot..... By hinging your doors 'the other way' , you may find they don't open fully, as they will probably hit the fenders /mudguards.
As Bobhenry said .....It's your build..do it the way you want.
jackdaw
Images: 124
Postby kennyrayandersen » Thu Jul 16, 2009 6:27 pm
Dare to be different, just not TOO different! :lol: :lol:
kennyrayandersen
Images: 38
Postby jdarkoregon » Fri Jul 17, 2009 12:28 am
Don't forget, Gull-Wing doors are an option
Good luck in your decision
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Boodro » Fri Jul 17, 2009 11:51 pm
I had a problem with my doors swinging open & I just put a bungie cord from inside handle to the other inside handle when I am going down the road. Never had a problem since. 8) 8) Good luck. :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
DOORS
Postby thewhinge » Sat Jul 18, 2009 12:30 pm
Well i have decided to go for the "suicide" door option!
Thanks to all who replied your feedback was most helpfull.
thewhinge
Images: 24
Re: DOORS
Postby Lou Park » Sat Jul 18, 2009 1:01 pm
The Whinge wrote:Well i have decided to go for the "suicide" door option!
I am curious as to why. When your inside and sit up the door knob is right
next to your arm. If you put it the other way you will have to reach behind you to open the door.
LOu
Lou Park
Images: 5
Postby mikeschn » Sat Jul 18, 2009 6:56 pm
In my mind suicide doors are awkward and uncomfortable. they also don't open all the way due to interference with the fenders. And if you don't latch them properly before leaving on a trip, watch out. but to each his own.
Postby Marck » Sat Jul 18, 2009 8:19 pm
Hmmmmmmmm :thinking:
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
Marck
Images: 64
Postby jackdaw » Sun Jul 19, 2009 2:25 am
Bristol Delica had a Gul-Wing door on his weekender when he first built it.
He's now changed it to a conventional 'hinged at the front' type. If gas rams or dampeners were used, and the door opened full , it could be a great trick.
jackdaw
Images: 124
Postby kennyrayandersen » Sun Jul 19, 2009 6:34 pm
I was thinking the same thing do to aesthetic reasons (I thought the long hinged side of the door would look better on the aft side – it would match the front contour of the tear better), but then I realized that practically it makes more sense to put the hinge on the front:
Easier to open from the inside
Doesn’t interfere with the fender
If you use a hurricane-type, it seals better against the going-down-the-road wet (rain road water etc.)
Decrease the chance of catastrophic failure if you leave it unlatched
And I hate to say the next one, but…
I think it would be easier to defend yourself (just my opinion)
kennyrayandersen
Images: 38
JUst throwing this out there!
Postby KyKamper » Mon Jul 27, 2009 10:52 pm
Pocket Doors? Sliders ?
Has anyone ever done it? sure it would make the door side exterior wall thicker but might be pretty cool?? :thinking:
KyKamper
