angib wrote:If you want to do a really neat job, get 'bi-axial' glass - this has the glass strands at 45/45 instead of 0/90 and you just would not believe what complex shapes this will conform to, without any puckers - applying one piece of glass to the end of a football is perfectly possible. Bi-axial (some pros always say 'bi-sexual'...) is a specialist product and is only usually available in cloth, not ready-made tapes.
Andrew
i've made patch repairs using 6mil vapour barrier and smoothened it out with a squeegie then taped the perimeter down so it won't curl. once the epoxy is cured the surface is near perfect and the edges of the epoxy are feathered in better that not using plastic. it seems to pool the resin in the little low spots in the weave too. no second application to fill the weave. like anything though it takes a little practice and experience to know what you can get away with.Corwin C wrote:+1
on the use of bias cut strips. They will go around compound curves and odd corners that tape could only imagine. Handle the strips with care and you shouldn't have any stringing of the fiberglass.
I personally have never tried the plastic wrap idea (but I'm going to try it on my next project)...should work, I'm just wondering how much the plastic distorts the surface (harder to fill?)
