Grid Runner Adventures wrote:I will be toting the whole system around with me. the digester is an old propane tank. I will be cutting a 4 in hole in the top around the exiting hookups, and welding a 4in diameter pipe to it few inches tall, this will be my feeding tube. I am building a closed system batch load digester.
eamarquardt wrote:I saw a TV program with the two English blokes who travel around England solving energy issues with "green" solutions. They did a segment on a "poo" (as Mike Rowe calls it) digester. They had a huge storage contraption that floated in a big pool of water. It was a huge production and took a couple of weeks or so to work as I recall (but my memory is sometimes not entirely accurate).
I think you gotta do some more homework, maybe.
I have PERSONALLY welded on a propane tank. I obtained two roughly 25 gallon tanks with rusted bottoms, cut the bottom off of one of them, the top off the other, welded them together to make a big air receiver.
I've heard rumor that propane, diesel, and propane will seep into the pores of the metal, be released with the heat of welding, and go BOOM to the detriment of one's health. Maybe gas and diesel but I find it hard to belive with propane. Two ways to solve the issue. Keep flushing the tank with fresh air while welding so you can't reach a combustable mixture or fill the tank with a non combustable substance as in water, argon, or CO2. Me, I cut the tank open with a saber saw flooding the cut with water and after opening the tanks up let them sit a day or so in the sun just to be safe. Then welded them up with no problem.
I frequent a local recycling yard and often see SS water tanks from solar water heating systems that were sold in the early 80s. Most of the heater was plastic and didn't hold up to the sun/weather but the tanks were as good as new. Maybe you could scrounge around and find some of them.
Gus
