moving the axle harborfreight folding trailer.
Postby Grid Runner Adventures » Thu May 13, 2010 11:36 am
what happens if your tongue weight is too much after you build your trailer?
I have the folding harborfreight trailer, it appears like i could undo a few bolts and drill new holes and slide the axle assembly forward a bit to offset the weight
any of you guys had to do this?
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Re: moving the axle harborfreight folding trailer.
Postby absolutsnwbrdr » Thu May 13, 2010 11:45 am
Grid Runner Adventures wrote:what happens if your tongue weight is too much after you build your trailer?
If moving it anywhere, you'd want to move it back.
I took my chances and kept it in the stock location.
Either way, you can offset the trailer balance when you load it with gear.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Larry C » Thu May 13, 2010 11:59 am
The best method I have seen for the HF trailer is add a 2x2 tounge extension that extends back to the first or second cross member. it fits betweem the plates on the end of the stock tounge.
Larry C
Images: 78
Postby Grid Runner Adventures » Thu May 13, 2010 12:09 pm
if you move the axle back it adds even more tongue weight.
Postby bobhenry » Thu May 13, 2010 12:28 pm
I missed 8 very important points :roll:
What are you towing with ?
What actually is the tongue weight ?
What does the trailer weigh ?
Are you towing at or near level ?
From nose to tail of the body only what is the length ?
From centerline of tire (dust cap ) to tail what is this measurment.
Is the galley heavily or lightly appointed and stocked?
Tongue box or not ? ( probably not the stock tongue is too damn short )
I just lengthened mine and I really wish I had taken 2 minutes to drag out the bathroom scales and checked before and after ! :x
After the tongue was lengthened 18" it actually seemed lighter as I lifted it up but this makes no sense. I can only attribute this to leverage a longer lever means less work to lift.
Here are the pics of my tongue repair
Chubby tows much nicer now and backing up is a breeze. I have now done this with all 3 of my tiny trailer and the 2x2 1/4 runs front to rear the rear was drilled and shimmed slightly to accept a 1 1/4 class 2 drawbar so accessories can be mounted at the rear.
Postby madjack » Thu May 13, 2010 7:02 pm
...lotssa folks move it to the rear to offset a too light tongue...no reason, it couldn't be moved forward for the opposite reason...look for some of the posts on moving it rearward and apply to your situation keeping in mind such things as where the trailer folds and cross member placement............
Postby Grid Runner Adventures » Thu May 13, 2010 10:40 pm
k. ya my design just has a bench/bed in the back and the galley/shower/bathroom is in the front of the camper. so how... do you build a camper to see where the weight will be but the wheel wells.
cant quite figure that out heh.
Postby bobhenry » Fri May 14, 2010 6:41 am
DUH ! I should have looked in your album I was thinking teardrop. My ritz 14" camper is a front galley standie and the wheels are almost dead center of the body. A couple smart fellas here on the forum have built the bodies off frame and found the balance point. If you were to do this and move the axle centerline 10 to 12 percent of the body length to the rear after you find that point you should have an ideal tongue weight without being too heavy.
Postby Miriam C. » Fri May 14, 2010 6:54 am
:( Well I can't find Andrew's balance sheet. Basically you guestimate your weight and get the tongue weight at or about 10-15% of the total. You really can do this but remember that paint and screws add weight.......
Maybe someone has Andrews sheet??????????? :cry:
Postby rainjer » Fri May 14, 2010 7:45 am
rainjer
King Koleman
Images: 11
Postby Grid Runner Adventures » Fri May 14, 2010 7:57 am
ya but you have to build wheel wells in if you build it off frame still ? do you just build it and cut them out after the fact ?
t/wt
Postby boxcar » Fri May 14, 2010 9:38 am
You can compensate for a heavy toungue build like the one in your album by moving the holding tanks to the rear of the trailer.....Boxcar...
God Bless....
boxcar
Images: 58
Postby Grid Runner Adventures » Fri May 14, 2010 9:56 am
there's an idea I could put the two golf cart batteries back there to balance out as well
Postby Miriam C. » Fri May 14, 2010 2:45 pm
rainjer wrote:http://www.angib.pwp.blueyonder.co.uk/teardrop/tear81.htm
Jeremy
Oh goody---the trailer balance spread sheet!
Thanks Jeremy! Hey guys if we all bookmark this it will not get lost again...... :twisted: ;)
Skinning a cat!
Postby eamarquardt » Sat May 15, 2010 9:00 pm
Grid Runner Adventures wrote:there's an idea I could put the two golf cart batteries back there to balance out as well
At the risk of getting criticized for advocating "cat skinning", there is more than one way to skin a cat (or achive proper trailer balance). Get as much of the weight of your trailer as close to the axle as possible.
Yer on the right track now.
Gus
eamarquardt
Images: 150
