Some Interior work Dunn.
Postby Classic Finn » Thu Jul 15, 2010 4:36 pm
Here are some pics of the interior work with Headliner and Upholstery.
Last with mahogany decor strip testing and fitting. Still trimming needed but gettn it dunn ;)
Also installed are the Marine Led Reading Lights
Classic Finn
Midnight Sun Voyager
Images: 146
Postby dh » Thu Jul 15, 2010 9:27 pm
I like the carpet, how is it attached?
dh
Postby Jst83 » Fri Jul 16, 2010 5:48 am
:applause: Very nice, I'm starting to become a fan of cloth walls and ceilings
Jst83
Images: 215
Postby Classic Finn » Fri Jul 16, 2010 8:50 am
dh wrote:I like the carpet, how is it attached?
Hello there. Its a Marine Headliner that will not mold, and easily cleaned, that has been installed with contact glue. This glue that we used is very good and is with a very strong bond.
There will be 2 or 3 mahogany decor strips running crosswise. This will also add some extra decor to the interior as well since the side walls are Mahogany. ;)
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 16, 2010 8:53 am
Jst83 wrote::applause: Very nice, I'm starting to become a fan of cloth walls and ceilings
Thank You Scott. It will certainly look nice when its completely done. It makes the interior look bigger as well even though its a light beige in color. Kind of a scary thought since light colors get dirty fast and everything shows.. but it cleans up easy enough.
Just got to be clean upon entry :lol: :lol:
Classic Finn
Images: 146
front windows
Postby streetrod23 » Fri Jul 16, 2010 9:27 am
looks nice I have a question on how to install the small front teardrop windows. I am at that point and need some advice , ANYBODY .Thanks
streetrod23
Images: 21
Postby Spotman » Fri Jul 16, 2010 9:54 am
:applause: Beautiful, so far. You know you will have to keep your dog out of it... you will never find it. :roll:
Bob
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Re: front windows
Postby Classic Finn » Fri Jul 16, 2010 10:35 am
streetrod23 wrote:looks nice I have a question on how to install the small front teardrop windows. I am at that point and need some advice , ANYBODY .Thanks
Hello Winnipeg ... Actually the windows I have are quite easy as well as inexpensive to do. Are you talking about the type of windows Ive gone with?
These windows are not for sale anywhere however the materials are inexpensive. 2 holes cut to your desired shape height n width. Rubber Window Moulding and plexi equivalent or you can have someone cut glass for you. I did it the home way. Or should I say my way :lol: ;)
Im not sure if its the proper way but I got it dunn the Finnish Way :lol: :D
Next time I install these I will have 2 aluminum window frames made up. This works fine though.
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 16, 2010 10:37 am
Spotman wrote::applause: Beautiful, so far. You know you will have to keep your dog out of it... you will never find it. :roll:
Bob
Hey Hello from Finland Bob. Thank You.. Our dog is just a bit lighter in color but at present since she is shedding it will give it some color combo. :lol:
I,ll take more photos of it as we progress.
All our best to you :thumbsup:
Classic Finn
Images: 146
Postby streetrod23 » Fri Jul 16, 2010 1:20 pm
Wow, That simple.. I purchased a piece of the rubber to try. Did you frame around the window at all. I assume the rubber that goes on the body covers the 1/8 ply and the alum. skin. Did you use any sealer at all. Does the fact that the body is slightly curved at that point create any problems, Any leaks? Sorry thats a lot of questions, thanks again for your quick response
streetrod23
Images: 21
Postby Classic Finn » Fri Jul 16, 2010 2:27 pm
streetrod23 wrote:Wow, That simple.. I purchased a piece of the rubber to try. Did you frame around the window at all. I assume the rubber that goes on the body covers the 1/8 ply and the alum. skin. Did you use any sealer at all. Does the fact that the body is slightly curved at that point create any problems, Any leaks? Sorry thats a lot of questions, thanks again for your quick response
Give me about 30 minutes and I,ll tell you more about it. ;)
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 16, 2010 2:57 pm
Ok here,s a few photos.
I started shaping the windows to be on a template. Just playing with a piece of wasted soft board. Actual paneling of sorts here.
I had my rubber moulding at hand also.
I measured the height width and of course center and marked them all.
I installed the entire template onto the tear front and started cutting and carving. I only had a Handmade Finnish Knife at the time too. ;)
In order to shape the front half I had to kerf or make cuts onto the 50mm
or 2" aprox. thick styro. thats in order to get the curved fit.
The thickness of the window plexi equivalent is 3mm.
Cutting the curve for the windows was the most fun part. Dont make the curves too sharp or steep. You have to bend the rubber moulding properly to it also, and so that the locking moulding on the back sits as well as locks the plexi or glass and seals it tight.
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 16, 2010 3:14 pm
Yes I did frame around the windows. As well as made a sill of sorts around the rubber moulding for it to look a bit better. I used was it 2 or 3mm bendable ply. Its basically nothing more than a trim ring inside.
Yes the rubber does cover the thickness of the ply and aluminum in your case. We didnt have wide enough al here so I used a layer of 3mm ply and then fiberglass sheeting that is used for truck trailers, horse carriages here. Worked out well. But in any case yes covers your ply n aluminum.
Yes make sure you seal it properly. I have a moulding that has an additional locking moulding to tighten up the seal as well as sealant all around the body side of the moulding as well as the window side of the moulding.
What I did was heat the plexi equivalent and bend it slowly to the shape of the tear front. This was with a hair dryer type hand blower.
I did reseal a few weeks ago since I noticed a small leak. I took it all apart and resealed everything. Had I done it the first time around I would have avoided this. Live n learn I guess. Now we tested it and no leaks. We had a downpoar yesterday and no leaks at all. So yes do seal properly as you install it. Dont leave it till later. ;)
No problem in you asking questions. I did and learned from it and still learning. :lol: :lol: Glad to help if I can.
Let me know if you want more pics. This is only my way of figuring this design out. Someone would have done it differently. Also I have no garage. So majority of this tear was born under the Arctic Skies which is my garage. Winter or Summer. :D
Do I like the style of this window. Ohhhhhhh Yes. I,ll make another set on another tear .. :lol: ;) :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 16, 2010 3:20 pm
By the way. Over the fiberglass I have 10mm of foam and then the Marine Vinyl. Its held up for a few years already and no garage except for a heavy duty portagarage or shelter.
;) :thumbsup:
Classic Finn
Images: 146
Postby streetrod23 » Fri Jul 16, 2010 3:30 pm
Thanks so much for the info, I have been considering this for the entire build and I will now be doing it. I am close to that point now. Your help and others on this site has been amazing as this is my first tear. the pictures you took time to post are great.The thought of getting help from someone in Finland is so cool. Thanks
streetrod23
Images: 21
Users browsing this forum: Bing [Bot] and 8 guests
