Deryk the Pirate wrote:dh, the outside intake on the right side would be drawing air from the galley, the left side is vented and the box on the exhaust side is vented to the side as well. I was just wondering if he has any issue with it.
The vented battery box is a great idea and I can vent it on the opposite side of the trailer from the ac unit.
deryk
Again, keep in mind there are TWO air circulation patterns, one across the evaporator, which cools your cabin, and one across the condenser, which removes heat from the condenser, which would normally be completely outside if used in the window of a house.
The two circulation paths never cross. Inside air stays inside, and outside air stays outside. The air circulating in my diagram above never enters the sleeping cabin.
On the front side of the AC Unit, there are intake vents on the bottom that suck air in and across the evaporator coil, and vents at the top where the cold air blows out.
If you use a battery box, you will STILL have to separate the intake air from the exhaust air on the condenser side, or you will burn up your AC unit. So, your battery box would have to be divided into two chambers, with vents for both cambers.
Clear as mud?
My setup was made from scraps of lumber and 1/4 plywood, with some heat resistant paint on the inside of the hot side box -- all stuff I already had. Cost? Zero.
CD
