Dooner wrote:And the hot tub goes where?
alanm wrote:Mike:
How does the design stand on your TAB L? In particular, what did you plan for the frame? Is it custom, or did you figure on a purchased unit?
Along that same line, what was the frame you used for the ET? From the pictures, it's a purchased unit, but I'd like to know which one you used.
Thanks,
angib wrote:surveytech wrote:I would call it the Tilde, since it is one key above the TAB
Now, you see, that is the sort of flash of genius this forum should be famous for! Superb.
Andrew
H@nk wrote:I just got the pictures and drawnings of the N@B T@B at home and they are splendid. Made by both Mike and Andrew, or Andrew and Mike, I cann't consider who comes first in name
