madjack wrote:...looks good Lynn but I do have a question for you...have you considered the wall to fender clearance...depending on build technique, it looks like you could have some clearance problems mounting the walls......
madjack wrote:have you considered the wall to fender clearance...depending on build technique, it looks like you could have some clearance problems mounting the walls......
Miriam C. wrote:Lynn you guys are moving right along there.I would sand the primer off anything to be glued and wipe it down with some paint remove. Not saturated but cleaned.
Secondly, are you going to resin your floor or the under side? We have people who paint the underside of the trailer instead of the evil smelling black goo.![]()
