Covering Screws
Postby Miriam C. » Wed Feb 07, 2007 11:17 pm
Lynn
My side walls are glued on and I have screws at the top an bottom. That will be covered with trim so they are flush. The top of the side is screwed into the spars and the bottom into the floor from the outside. The glued frame is then screwed to the floor also.
I did worry about it at first but the roof is the same way. Glued to all the spars and ends with screws at the ends where I will have trim.
Postby halfdome, Danny » Wed Feb 07, 2007 11:21 pm
Lynn Coleman wrote:
halfdome, Danny wrote:Counter sinking screws into 1/4" plywood won't leave much meat to pull everything up tight. The screws are only there as a clamp until the glue dries as it is when you glue & nail things together. Why not just use the best glue possible and just fill up vessels like buckets, cans etc and anything else of weight and place it all on top of your framing as weight clamps while the glue dries for a day or two. Make sure every inch is covered with glue & weights. This way you don't need the screws or need to fill those countersink holes. I use a soft plastic Bondo spreader to spread my glue on projects as it's flexible and spreads glue very fast.;) Danny
We glued first with weights, so you're saying we don't need to put screws in? That would be awesome. :thinking: Lynn
As long as your plywood and framing is glued tightly together it would be a waste of time and effort to use screws. When you buy plywood that is glued together under high pressure you don't need screws to keep it together. I make woodturnings that are held together with glue & clamps and they hold up like solid wood. Wood glue joints ,if properly done, are stronger than the wood itself. :thumbsup: Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby bledsoe3 » Thu Feb 08, 2007 12:29 am
Lynn, I used screws to "clamp" the wood until the glue dried. Then I removed the screws.
I could have left them if they didn't stick out the other side.
bledsoe3
Images: 112
Postby Lynn Coleman » Thu Feb 08, 2007 12:29 am
Hi Danny,
Thanks so much for this time saving information. Wow, I'm excited now, we've eliminated a day of work. :worship:
Lynn
Lynn Coleman
Images: 115
Postby Lynn Coleman » Thu Feb 08, 2007 12:31 am
bledsoe3 wrote:Lynn, I used screws to "clamp" the wood until the glue dried. Then I removed the screws.
Awesome two confirmations that I don't need the screws, well not in that spot anyway.
Lynn
Lynn Coleman
Images: 115
Postby Steve_Cox » Thu Feb 08, 2007 7:19 am
Lynn,
To screw, or not to screw: that is the question:
Whether 'tis nobler in the mind to suffer
The nails and staples of outrageous joinery,
Or to take arms against a sea of plywood,
And by opposing glue them? To screw: to nail;
No more; and by using epoxy say we end
The heart-ache.
:lol:
Steve_Cox
Images: 196
