bdosborn wrote:I don't know what the BTUH is of this unit...
Woody wrote:I did find a formula to figure out btu's reqiured to cool a given space...
I found that a 5200 btu A/C is a little overkill. It cools fine, but cycles fast...
You should check out Larry Sorenson www.outbackteardrop.com...
I noticed that the above calcs don't seem to take into account the effects of humidity level.
You mentiond it using 600 watts. I assume that is when the compressor is cycled on. What about when the compressor is off? Did you measure the 600 watts, or just look at the name-plate rating? How long is the on cycle, and the off cycle and at what outside and indoor temps?
Larry's site was the first site I saw and I too got the bugLarry's site, along with Dave & Louise's page are the ones that inspired my interest in TTT & TD.
Woody wrote:You should check out Larry Sorenson www.outbackteardrop.com site he spends alot of time in the desert and he built a mini swamp cooler and states it work well for him. He might be someone to talk to about his cooling system which he shows on his site
It's listed in the above message. 28.5 kg = about 63 lbs. Is your trailer gong to have a 12V battery? Run off the 12V and keep the battery topped off with a standard RV 120VAC-to-12VDC converter (or PC power supply, as mentioned in another thread.)steve wolverton wrote:fasttimes - Neat stuff. I wish they had a split 110 unit that size. Any ideas on the weight?
AFAIK, they are currently using Danfoss compressors and control electronics. These can be found easy. I would think that the "balance-of-system" items are also probably off-the-shelf items, or at least sutible replaments could be found if the company went under. A service manual would be nice. I'll have to ask, next time I contact the company.The only thing that makes me nervous about that unit is finding parts/service.
The 2000BTUs of the Petcool AC is close to ideal, especally if you want an AC model. I'm not a fan of the hose method of supplying the cooled air/return air, but it could be worse (a window unit-- yuck.)I want a 110 unit, and so far the Petcool is looking like the way to go. $400 is a big pop, but I imagine well worth it in Texas in July.
