Aluminium siding like Camp-inn's
Postby shamrock » Tue May 08, 2007 10:10 am
Cary.. 1 other thing when we were talking at the "Cooler near the lake" get together you told me about the type of adhesive you use to bond the aluninium skins together at the seams, but I cant rember the name of it?
Thanks.
Scott
shamrock
Postby Cary Winch » Tue May 08, 2007 4:19 pm
Scott,
Any number of urethane sealant/adhesives will work well. Usually the easiest thing is to go into your local auto parts store and get at tube of the urethane adhesive used to install car windshields.
If you can track it down the prefered product we have found is Sikaflex. Much easier to clean up and super good adhesion.
Cary
Cary Winch
Teardrop Manufacturer
Postby shamrock » Tue May 08, 2007 4:54 pm
Thanks Cary this will be a huge help
shamrock
Postby Duane King » Tue May 08, 2007 5:46 pm
Cary,
I've been looking for the Sikaflex eurathane adhesive that you recommend. Apparently "Sikaflex" is a product name given to a family of adhesive products. Do you have any numbers that might narrow the search to the exact product you are using?
Duane King
<img src="http://www.mikenchell.com/images/roadhouse.jpg" >
Duane King
Images: 98
Postby shamrock » Wed May 09, 2007 10:09 am
WOW Duane, you ant kidding.I went to there web site and thay must have 60 or 70 adhesives.
shamrock
Postby Cary Winch » Wed May 09, 2007 10:47 am
Um, ya. really good point Duane. Sikaflex 221 is what we use.
Cary
Cary Winch
Postby Duane King » Wed May 09, 2007 11:55 pm
Cary,
Do you use this Sikaflex under all of your exterior mouldings? You told me on the phone how easy it is to clean up, but I forgot the technique you use. Does it just wipe up like rubber cement, or do you need a solvent of some type?
Duane King
Duane King
Images: 98
Postby Classic Finn » Thu May 10, 2007 4:52 am
Cary Winch wrote:Um, ya. really good point Duane. Sikaflex 221 is what we use.
Cary
Cary you are correct Sikaflex is a great product.. I found the 221 here..
That stuff works great..
Classic Finn :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Cary Winch » Thu May 10, 2007 9:00 am
We do use it under the trim. The reason is it easy to clean up is it doesn't really adhere when not under pressure. So, what ever squirts out you don't touch and let it set up. Once it completely dries your trim it tight to the trim with a sharp knife and peel it off the trailer. Really easy. Any little stubborn spots come off easily with some laquer thinner. If that were silicone or other urethanes you would have issues getting it off the metal after it sets up.
Cary
Cary Winch
