spray on foam
Postby Todah Tear » Wed May 09, 2007 12:13 pm
Duane,
Maybe try a combination of the peanut stuff that Joane mentioned and the canned spray Great Stuff or a cheaper brand. In some parts of my tear, I used the great stuff (Wal-mart carries Great Stuff and another brand that is less expensive.) I bought the Great Stuff from Lowes and it was $5.96, then I went to Wal-mart and it was $3.$^@$^. I happened to mention that it was cheaper than Lowes when I checked out. The next time that I went to buy it, Wal-mart had gone up a whole $1!. They have another brand in a green can that is cheaper and expands just as well. I have used it and it cuts with a hand saw or a Dremal.
Using a combination things, you might only be out of $50 bucks or so as compared to $225. ...just a thought.
Todah
Todah Tear
Images: 282
Postby Duane King » Wed May 09, 2007 1:13 pm
About how far can you go with a can of that Great Stuff?
Duane King
<img src="http://www.mikenchell.com/images/roadhouse.jpg" >
Duane King
Images: 98
Postby Todah Tear » Wed May 09, 2007 1:22 pm
I'd say, 1 can will get sufficient expansion to cover a 24"W x 6" H x 6"Deep. That may be undershooting, if you remember to not saturate one area with too much (When that happens, it doesn't expand well.). Leave room for it to expand.
Buy one can and experiment...and by all means, WEAR GLOVES. This stuff is worse than Gorilla Glue when it comes to getting it off the skin.
Todah
Todah Tear
Images: 282
Postby riverfront » Wed May 09, 2007 10:00 pm
I used the Great Stuff on several projects and it really expands.
When hard I took the blade out of my bow saw and used that to cut it leval.
Worked for me!
riverfront
Postby BrwBier » Thu May 10, 2007 6:33 am
Lately I have seen contractor sized cans of Great Stuff. It has a different type of valve/ spray head. I think it is cleanable/ reusable. Normally you get just a straw sized stream and it is hard to do a wide flat area. Maybe the contractor can has different spray pattern, but I'm not sure. As far as getting it cut off to the level you want almost anything cuts it, knife, saw, hot wire, sanding. I would say go for it, lots of people will be interested in the results.
Brwbier
BrwBier
Images: 100
