doug hodder wrote:Miriam...here's an idea....if you have a bench planer, just keep planing down about a 3' stick of material cut the width you want and every pass on the planer, check how it bends..when it gets where you want it that's how thick you are going to need to go...is the grain really straight on the edge? If it's not, you could potentially have problems with it blowing apart once it's on and bent up...sorry, just my opinion, typically straight grained woods bend much better than something with any figureing or other "wild grain"...other opinions may vary...Doug
Doug, most of the stuff I got to do the top trim was fairly straight grained and has very little spalting. I have a strip that is thiner and it bends like crazy. Easier to bend where the patterning curves.
At this point the only thing I know to do is plane it (wood shop has a big planer) and make it thin until I can get back and make it thicker. Probably doesn't even need to be thicker. Just thought about rounding the top edge.
