sheltie wrote:So if there is no insulation? Do you get cold? I am new to the forum and have been reading a lot. My husband and I are in the planning stages of a 6 x 10 frameless with a bathroom. We are in New Brunswick, Canada and we will be using the camper mostly in spring and fall. Without insulation would we be warm enough with a small heater or do we need to insulate?
Cindy
Greetings Canada and Hello Cindy
I live in the Country of Finland.. I do believe our climate is much like yours.. On mine I used 3/4 inch side walls or if its 20mm.. and front to back on roof I used 50mm about (2 inches ) blue styro which is much better than the normal styrofoam...
I may have gone too thick but ok its warm..
Im not sure yet as to how cold the walls will be without the insulation there but I think it maybe a little cold if a bare back is to it.. especially in late fall or early spring...
Next tear I build will most definitely be insulated throughout..especially for our climate..
Also at 1st we wanted to use the tear for summer but the teardrop fever progressed...
Ohh Cindy be careful Teardrop fever has no cure it only progresses..
Welcome to the Forum and have fun..
Again Greetings from Finland
regards
Classic Finn
