Does This Plate Need Glue ?
Postby madjack » Thu Sep 13, 2007 12:29 pm
Heikki, if there is trim/screws all around the edges, you should only need sealer/adhesive on the edges and screw holes....
Postby Classic Finn » Thu Sep 13, 2007 1:03 pm
madjack wrote:Heikki, if there is trim/screws all around the edges, you should only need sealer/adhesive on the edges and screw holes....
10-4 Mr. Madjack
Thank You Kindly.
Heikki ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Classic Finn » Thu Sep 13, 2007 2:54 pm
Madjack this is what Im using as a Sealant...
Heikki ;) :thumbsup:
Classic Finn
Images: 146
Postby Gerdo » Thu Sep 13, 2007 4:39 pm
If you are penetrating the skin, YES! I would use some of the gray rv caulking putty behind the screws. I would just put a marble size ball behind the DP where your screws will go. If going thru the frame or something that it doesn't matter if water gets thru, then it is your option. This is what I did on all of my trim and I have no leaks.
Gerdo
Images: 156
