Esteban wrote:Bippy, Gaston's fiberglassed foam sided teardrop might intrigue you to follow your dream. It's a beautiful masterpiece. Personal Gallery of Gaston
Bippy wrote:Hi there, I'm interested in building an ultra light TTT, kind of like the Puffin (in fact, a LOT like the Puffin- I read that thread strait through until 7:00 in the morning. Wow. Amazing stuff.)
I was thinking of building it with fiberglass, since it's lighter than wood,
Bippy wrote:
and the difficulty and learning curve seems to be about the same with wood construction as with fiberglass.
Bippy wrote:
The best site I've found describing how to build with foam and fiberglass is http://www.rqriley.com/frp-foam.htm but I will flat out admit I don't know what I need to know about what all the various parts do and how they interact with each other, but I DID notice that there were people building with foam, and then taking the foam away later to just leave the fiberglass shell.
Bippy wrote:
That got me thinking that perhaps the foam is NOT so important to the finished process, and wondering if I could find something cheaper than foam to build with...
I am currently toying with the idea of building a frame with poplar or some other light and lovely wood, and then instead of using plywood, using fiberglass screening, like this stuff from home depot
Then I'd lay the fiberglass cloth over that, use one of the epoxies, and lay a few layers over in different directions for strength.
Does anyone have any idea if this would work?
Bippy wrote:
My thoughts are that the plus side to this is, it's cheap as heck, would be sturdy and rot-proof, and very very light.
2bits wrote:StarWars, did you not see the plane, and the PT Snoozer? It can be done, although yes, not cheaper or easier.
elderjay wrote:How much does a sheet of 3/4 ply for the sides weigh?
