Greywater
Postby prohandyman » Tue Jan 22, 2008 9:28 pm
MJ said he had a foul taste from his. Maybe the glue or something in the PVC.
Dan
prohandyman
Images: 785
Postby cuyeda » Tue Jan 22, 2008 9:53 pm
prohandyman wrote:MJ said he had a foul taste from his. Maybe the glue or something in the PVC.
I am not an expert on PVC grades, but if any of the designs included using potable PVC materials it would be improved. Even with on board water, I would not use it for drinking. Cooking and cleaning would be ok.
Quick internet search note: If the pipe is for potable water, a laboratory seal or mark attesting to suitability for potable water.
Cliff & Vanessa
cuyeda
Postby toypusher » Wed Jan 23, 2008 6:40 am
Cliff,
I have a plastic (made for potable water) tank and we do NOT drink the water, we always take bottled water when camping. Tanks systems are just too difficult to maintain in a truely sanitary manner.
toypusher
Images: 324
Postby prohandyman » Thu Jan 24, 2008 8:26 am
Mallett
I see in your photos the flex drain line. How does it connect to the 1" fitting? It looks like your system is tight against the floor bottom, so did you have to cut a hole in the floor to allow room for the fitting as well as the hose?
Pretty cool system!
Dan
prohandyman
Images: 785
Postby mallett » Thu Jan 24, 2008 9:04 am
prohandyman wrote:Mallett
Pretty cool system!
Dan,
I soaked the drain line in hot water and just slide it on to the fitting with no clamps. It fits real tight. I made a paper template of where the fittings came out of the PVC. Then I drilled two holes through my floor. One a 1 3/8" for the drain line and the other 15/16" for the vent. I put a little silicone around them to seal them off. I soaked the drain line in hot water and just slide it on to the fitting with no clamps. It fits real tight.
Mallett
Every man's work, whether it be literature or music or pictures or architecture or anything else, is always a portrait of himself.
- Samuel Butler (1835-1902) British writer.
mallett
Images: 61
Postby madjack » Thu Jan 24, 2008 12:10 pm
Cliff...those are not my photos...as far it goes, I wouldn't do the PVC water tank again...although, I used PVC, rated for potable water, it would taste bad(not plastic...just bad)...it was way too much of a hassle to keep clean and sanitary and I would just as soon use it for washing only...in the future, I would just use a camping water container(think 2.5gal blue jug) and acquire water as needed...plus, keep some bottled water for drinkin' and coffee makin'........as always with such things...YMMV
Postby jeep_bluetj » Thu Jan 24, 2008 2:59 pm
My tank is 2 6" pvc pipes about 5' long. (15 gal or so).
It's a bit plasticy, but not bad. If I have nothing else to drink or make coffee with I'll use it.
But normally it's wash water only. I keep it clean by a cup-o-bleach shoved through after every trip. It's pretty bleachy as it stored, then I rinse again before the next fill.
PolyEthelene (standard RV) tanks have much less 'flavor' to them after they've been used a bit. But since I use air pressure for the pump, I really needed something stronger.
-- Jeff --
jeep_bluetj
Postby cuyeda » Thu Jan 24, 2008 11:33 pm
madjack wrote:Cliff...those are not my photos...as far it goes, I wouldn't do the PVC water tank again...although, I used PVC, rated for potable water, it would taste bad(not plastic...just bad)...it was way too much of a hassle to keep clean and sanitary and I would just as soon use it for washing only...in the future, I would just use a camping water container(think 2.5gal blue jug) and acquire water as needed...plus, keep some bottled water for drinkin' and coffee makin'........as always with such things...YMMV
MJ,
Sorry for the missed reference. I picked those photos up on another thread. Perhaps something you made reference to. When the time comes to install a tank, I may look into a couple of vendors that make custom tanks if it is not to costly. Just gathering ideas.
Cliff & Vanessa
cuyeda
Postby prohandyman » Mon Jan 28, 2008 8:41 pm
Well Mallett, thanks to you, I now have a greywater holding tank. Looks very similar to yours. I need to install a vent in it, and it will ready to mount. :thumbsup:
Dan
prohandyman
Images: 785
Postby mallett » Mon Jan 28, 2008 9:04 pm
Dan,
The vents is very important. I put mine about 2 inches behind the inlet works great so far. I hope to take it camping this weekend to give it a real work-out.
Just looked at your picture gallery, Love the looks of your tear. How thick are the stripes that make up the sides?
mallett
mallett
Images: 61
Postby stedi » Wed Jan 30, 2008 1:50 am
mallett,
what hardware did you use to connect the pump of your hwod to your freshwater supply?
regards,
steve
the government does not produce one single bushel of corn, one single barrel of oil, or one unit of any other commodity. the only way it obtains the money that it awards to its chosen recipients is by taking it from others who earned it. this is called "voluntary taxation".
stedi
Postby mallett » Wed Jan 30, 2008 7:19 am
stedi wrote:mallett,
regards,
steve
Steve,
I used the Coleman garden hose adapter & spray hose adapter (took the spray head off).
Hope this helps,
Mallett
mallett
Images: 61
Postby Mary K » Wed Jan 30, 2008 12:50 pm
:shock: :shock: :shock:
What a great Idea. I have been putting off doing a grey water tank, cause I didn't want to deal with the 4" pipe. But this look so easy.
Thank you Thank you!!! Awesome Idea!!!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Re: Greywater
Postby wax » Wed Jan 30, 2008 2:38 pm
Alphacarina wrote:
mallett wrote:Made this grid out of 2" PVC pipe. It 51" by 24" which gives me about 25'. I found a program that figures the volume of pipe and it comes to 4.7 gals. I am planning on installing it under my teardrop between the 2" tubing. I have the inlet and outlet but will have to vent it.
Here is a link to the neat program for figuring the volume of pipe.
pages.prodigy.net/rich_demartile/files/pipe-vol.xls
*snip*
Since there's no pressure on your 'tank' you could have cut half or three quarters of an inch off of each side of your Tees and Elbows and you would have had room to add a sixth cross pipe to your 'tank' - That would have given you about another three quarters of a gallon of storage capacity :D
Don
you could also use a header pipe rather than the T joints and have the lengths as close together as you wish... well as close together as you can make them.
but only if needed of course.
wax
Postby nikwax » Thu Jan 31, 2008 6:16 pm
returning to freash water tanks for a moment, any experience with the ABS tanks
nikwax
Images: 30
Users browsing this forum: Google [Bot], Jimbodub and 3 guests
