Cheap sink for Galley
Postby Denny Unfried » Sat May 31, 2008 9:27 am
Many campgrounds won't let you drain onto the ground so now you need to take along some more weight like a gray water tank.
My tear is only an 8 footer and a useful sink would take up most of the counter top so I use a plastic kitty litter tub which is just the right size for washing etc. When on the road I put it on the bed and fill with small things to keep them from rolling around.
Just an attempt to keep it simple. 8)
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Re: Cheap sink for Galley
Postby jmullan99 » Thu Jun 05, 2008 7:47 pm
Ooooops. My ignorance is showing. What is the name of the bit type you use in a dremel to cut a hole in stainless steel?
John
BCC wrote:I have been pricing small SS sinks at the Big Stores. They all run over 50 bucks. I have found what I think is a cheap alternative. At W mart I found a large SS mixing bowl. I used a dremel and cut out a hole and intalled a drain with plumbers putty. All I have to do is cut out hole in the countertop and install. The sink and drain cost a total of $15.
jmullan99
Images: 29
Postby fornesto » Tue Jun 10, 2008 3:47 pm
We have the bowl sink but with no drain. I've found that once it's filled, its easy enough to lift out and dump in the bushes - keeps the dust down. We're pretty frugal with water so the most we're talking about is a gallon or so a day. The water goes the same place as a plastic tabletop dish pan and there's no fuss with grey water or a drain hose (tripping & mud under the trailer). I wouldn't change it next time. Plus, the "built-in" gives you a couple style points, if that matters. :lol:
fornesto
