Valterra water tank fill kit ?
Postby brian_bp » Mon Jul 07, 2008 1:29 pm
john wrote:Are these tanks like the valterra above designed for pressurized water like the water lines in a house.
No, RV water supply tanks are generally not pressurized at all.
john wrote:I guess what I am asking is when a water system is installed and the hose connected does the pressurized water also pressurize the water tank?
No, the water is pulled from the tank by a pump. If water is also supplied under pressure from the outside, that water line is connected on the outlet side of the pump, and a check valve in the pump keeps water from flowing into (and pressurizing) the tank.
brian_bp
Images: 9
