The "Simple"
Postby LindaH » Wed Jun 04, 2008 7:44 pm
Miriam C. wrote::thumbsup: Kids like to sit on the ground. You can also make the middle a table for them
EZ has his bunks dropped to make a similar couch.
:thumbsup: http://tnttt.com/album_ ... er_id=2202
It's so true that kids spend time on the ground to play!
I hope I am not taking away from cowboy's thread (sorry if I am), but what are the benefits to building a trailer in the more rectangular/boxed design?
In other words, is it easier to build vs. something more in the Benroy design?
I am new to the forum as well - so have lots of questions too.
- Linda
LindaH
Postby cowboy63645 » Wed Jun 04, 2008 7:49 pm
Linda, please dont feel that you are taking away from the thread that I started, if you have a question, please feel free to ask it, your not stepping on my toes at all!! because later on down the road I might have the same question you just asked and you will have already gotten the answer for me to look back on
cowboy63645
Postby LindaH » Wed Jun 04, 2008 7:54 pm
cowboy63645 wrote:Linda, please dont feel that you are taking away from the thread that I started, if you have a question, please feel free to ask it, your not stepping on my toes at all!! because later on down the road I might have the same question you just asked and you will have already gotten the answer for me to look back on
Thanks very much! :)
My fiance (Hinermad - David) on the forum and I are also just starting our build but are looking at a Benroy plan. I just like to know about others as well and their advantages.
It sounds like what you have in mind for your family would be perfect!
- Linda
LindaH
Postby cowboy63645 » Wed Jun 04, 2008 8:01 pm
my entire build is based around my family's outdoor needs. I picked a more boxed off style merely out of preference. I like the idea of using all of the space available to me.
cowboy63645
Postby DougH » Wed Jun 04, 2008 8:49 pm
Same with me, I picked the shape more on my needs than looks. I didn't want a galley and the box maximizes interior space. Also really wanted the front window/skylight and the shape also made that much easier to acomplish. I agree that the more tradional teardrop shape is much nicer to look at but I built for functionality for me.
DougH
Images: 86
Postby mikeschn » Thu Jun 05, 2008 5:33 am
It's mostly about looks. And looks are in the eye of the beholder.
I've done both, rounded, and squared off. Finally, after all these years, I've decided that I like the rounded off look better.
They are both equally easy to build, but have different challenges. For example, with the rounded version you don't really have to worry about joints. Just make sure your plywood skin falls on a spar. with the squared off version you have to make sure to seal your corner joints especially well, or they will leak. If you are using aluminum, you need a sheet metal brake, as long as your teardrop, so that you can bend the odd shaped trim.
Postby angib » Thu Jun 05, 2008 6:25 am
Ideas on those Squampster front bunks:
- The bottom bunk is on the 'floor', but the dropped footwell is right next to it so it's a suitable height for sitting/lounging, but they're looking at the knees of people in the dinette. The practical problem is that a bunk wide enough to sleep on is undesirably wide to sit on in real comfort - no problem for kids though, unless you're strict about no feet on the upholstery.....
- Grant's original Campster design has exactly the sort of hinged-bunk backrest that's being described.
- I would certainly suggest building framing into the front and side walls to take bunk supports at mid-height, so that the three-bunker could later be converted to a two-bunker.
- It's quite easy to design a bunk that can be lifted off its supports on the wall and repositioned on another support. The downside is that the bunk and mattress will weigh a bit so they're not that easy to lift in a confined space.
- Combining repositionable bunks with one that hinges down as a backrest is very hard - in the backrest position, the bunk sticks up through the next level of supports, so the support design and build becomes very complex.
- One way round the problem would be to put these bunk latches on all four corners of each bunk and have multiple holes in the sidewalls for all the different combinations of positions that are wanted.
(I'm not 100% sure I'd trust these without some way of locking them firmly in the extended position. And they will get heads banged on them!)
- Simply hinging the upper bunks on the front wall and lifting them up on strings and hooks during the day might be the simplest way:
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby LindaH » Thu Jun 05, 2008 7:12 pm
Thanks Guys for answering some questions and also Cowboy for letting me side-step his thread. 8)
I know David knows far more than me - but I still keep asking questions to learn more about different styles of TD's and techniques on how to build them each so that I can at least help him as much as I can.
- Linda
LindaH
