Painting PVC pipe (for a changing room frame)
Postby rdkng07 » Fri Jul 04, 2008 12:32 pm
I built a couple of hockey goals with PVC. I used some outdoor furniture grade PVC that I found on the internet. No ink marks on the tubing or anything like that, and it has a better finish, UV protection. and was a more rigid material then the plumbing stuff. They also had all the fittings, and the color was a true white. I wanted white, so I did not check for other colors.
Good Luck...
I don't remember the place, but here is an example.
http://www.candsplastics.com/
Rodger
rdkng07
Postby BrwBier » Fri Jul 04, 2008 7:56 pm
I neveer even knew that there were differant grades of pvc pipe. That is good to know.
Brwbier
BrwBier
Images: 100
