Cheers
Paul
PaulC wrote:I have trouble understanding why so many people can not grasp the principles of aerodynamics and, then realising that they are generally talking gobbledegook. The gains, aerodynamically, when towing a TD would be so minimal that it would probably take you all a 100 years, or more, to realise any financial benefit. If Andrew can be so kind as to put up his drawings of what happens to the air as it passes over a motor vehicle you should all be able to see that your time would be better spent travelling that beautiful country of yours.
Cheers
Paul
sushidog wrote:The underside if the Aliner is pretty rough aerodynamically with lots of protruding pipes, frame members, etc. Do you think a rubber air-dam on the front of the trailer would help?
RICHARD FURROW wrote:Why don't the big semi truckers use this instead of the big fiberglass fairings that they do?
RICHARD FURROW wrote:Why don't the big semi truckers use this instead of the big fiberglass fairings that they do? I really do appreciate the discussion. Best ay to learn is listen, then ask questions later!
Ricky
RICHARD FURROW wrote:This Website backs up a lot of what we all been talking about. It is quite interesting. When you really think about it, like someone earlier said, it want make a lot of difference in the long run unless you do a lot of cross country traveling, or several thousand mile a year at interstate speeds.
Anyway, here is the Website:
http://www.marama.org/diesel/frieght/co ... roOvw2.pdf
sushidog wrote:
The reason for such a tiny rig is primarily economy while towing, as we plan to tow 30-36,000 miles a year for an indefinite number of years.
