No Fender Welt to Fit.. Can anyone help?
Postby Classic Finn » Thu Jul 24, 2008 5:55 pm
Mary K wrote:Whats Fender Welt? What does it dooooooo?
Mk
Mary wit a K.. The fender welt prevents from dirt and sheeet.. getting in between the fenders and wall of the tear.. same purpose served on VW,s and some other cars.. ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Creamcracker » Thu Jul 24, 2008 6:16 pm
Hey Heikki here's some on Ebay:
http://cgi.ebay.com/ebaymotors/UNIVERSA ... enameZWDVW
How much do you need? What color do you need?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby BrwBier » Thu Jul 24, 2008 7:13 pm
Classic Finn wrote:I happen to have the caravan tent welting.. would that work? Also is it ok to use the vinyl that I have left over to cover the welting that is normally for the tent or awning ?
Let me get a pic of it to show you..
here it is..it has a round plastic inside.. :thinking:
Would the above work?
Classic Finn :thinking:
I think that would be a nice touch, matching the top.
Brwbier
BrwBier
Images: 100
Postby tinksdad » Thu Jul 24, 2008 7:32 pm
I think your idea would probably work just fine. I looked at the e_bay listing that somebody else suggested... and the description of the item said it vinyl wrapped. The pic looked like vinyl wrapped over a thin plastic tube and seamed very close to the tube (probably with something like a zipper foot on the sewing machine). I you have some short scraps, why not experiment and put a piece together and see how it looks and whether you like it or not. Personally I think if the welt matched the roof color it would look sharp!
tinksdad
Images: 155
Postby Steve_Cox » Thu Jul 24, 2008 7:56 pm
I bolted the fenders on then put down a bead of black silicone It looks like welting but works better in my opinion. But it still ain't welting if that's your preference. 8)
Steve_Cox
Images: 196
Postby G-force » Thu Jul 24, 2008 9:13 pm
Back in the days when fenders were large and bolted directaly to the bodies of vehicles, its is a rubber ribbon with one edge usualy rounded that was placed inbetween the fender and body. It filled the gap, made the seam look good, and prevented the two pannels from rubbing on each other.
Mk
Mike
G-force
Images: 22
Postby madjack » Fri Jul 25, 2008 12:21 am
Heikki, using the same fenders as yours, on the first tear, we were faced with the same problem...never did find any welting we liked and instead, used 1-1/4"x3/16th closed cell weatherstripping...adhesive on one side...we put it on the flat mounting face , level with the top edge of the fender...poke a hole thru the bolt hole, put it in place and bolt it down tight, the foam will seal everything better than regular welting and give you some vibration/shock resistance as well...you won't have the welting sticking up but the foam will give you a very clean finish line and will help hide any irregularities in the fender edge finish.....
Postby RICHARD FURROW » Fri Jul 25, 2008 6:11 am
Check this out. This place has welting that has a stainless or myler beads that gives a chrome welting look. My brother used it on his 1940 Ford and it looked great. A little pricey, but we only have two fenders!
http://www.chevsofthe40s.com/search.las ... chbtn.y=12
RICHARD FURROW
