Spar varnish
Varnish
Postby Senior Ninja » Fri Jan 02, 2009 12:54 pm
Hi varnish fans,
My td is similar to Roly's, just not as pretty. I three coated every piece of wood on the trailer. That includes the bottom of the floor and the interior. I like the look. It stays in the garage between uses and under an Easy-up when camping. I'm not planning to have to re-coat for a looong time. I really don't mind, though. I grew up in a paint mfg business and those voc's smell like $$$$ to me.
Building the TD was the best thing I ever made.
Senior Ninja
Postby wannabefree » Sat Jan 03, 2009 10:30 pm
I am getting a lot closer to varnish than I ever wanted to be. Frankly, I don't like it. It takes way too long to dry and it's real sticky. Aside from that I guess it's OK. It does a better job of pretecting the wood than lacquer, which I passionately prefer. I am using varnish on the interior and for sealing insides of wall panels, etc, but prefer to shoot the exterior with something less yellow. One recommendation -- use good stuff. Expect to pay close to $100 per gallon. Minwax Helmsman is cr@p, but you can get it at the big box and I thought it would be good enough for the interior. Sure wish I had gotten the good stuff. I can tell already I will be doing it over in a year or two. :x
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
