New build finally started!
Postby kennyrayandersen » Sun Jul 11, 2010 8:46 pm
Is it me, or is there a gap between the side walls and the cabinets? The cabinets could be built in place to add a bit of strength, though it isn’t a big deal – just an observation.
The build is looking good though!
kennyrayandersen
Images: 38
Postby jdaan » Sun Jul 11, 2010 8:53 pm
kennyrayandersen wrote:Is it me, or is there a gap between the side walls and the cabinets? The cabinets could be built in place to add a bit of strength, though it isn’t a big deal – just an observation.
Yes there is. It's tough to tell in the photos (and because I didn't really line it all up when I set it there), but the gap is the thickness of the 1/4" plywood inner skin. I'll be insulating and wiring the walls, then installing the inner skin before putting the walls up. There will be no gap at that point. Then I'll glue and screw the whole galley/cabinet section to the walls. I liked the idea of building the galley/cabinets separately, now I'm not sure why I thought that was a good idea. I think it may have been more complicated.
Justin
Build Thread: Here
jdaan
Images: 46
Postby kennyrayandersen » Sun Jul 11, 2010 9:04 pm
That makes sense and should be plenty stout when you get it screwed and glued together!
kennyrayandersen
Images: 38
Postby jdaan » Fri Jun 03, 2011 5:21 pm
Not a ton of work lately, but did get the outer plywood skin on. Next is the dreaded hatch and doors...
Justin
Justin
Build Thread: Here
jdaan
Images: 46
Postby jdaan » Fri Jun 03, 2011 5:22 pm
Oops, wrong thread.
Justin
Build Thread: Here
jdaan
Images: 46
