Insulation and Interior Sandwich Wall Question(?)
Re: Working on it
Postby Endo » Sun Jun 07, 2009 6:40 am
Alfred wrote:Hey Gang,
I am going to take a section of the camper wall with me, with a piece of the insulation and see if the insulation folks at Home Depot have any suggestions.
AL.
Perma "R" insulation will fit into the 3/4" space without a problem. It is available at Lowes.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Update
Postby Alfred » Sun Jun 07, 2009 1:13 pm
Hey gang,
Here's the update.
I went back to home depot and got the 1/2" pink insulation, which actually appears to be a better fit than the 3/4". As said in my previous email it is slightly thinner than the framing, but very close. At least it will not ripple out.
I returned the FRP for the time being. Despite the obvious positives to this product, I could not warm-up to the plastic shower stall look, and I think I will go with some sort of interior paneling, as yet to be determined.
I appreciate all of the feedback, and will keep you all posted to progress.
AL in Asheville :thumbsup:
Alfred
Images: 368
Postby Walt M » Sun Jun 07, 2009 5:47 pm
Hey Al, I used the foil/bubble/ foil Insulation. some one on the forum did a little test and if I remember correctly it was the same as 3/4" foam ins.
it's much easier to work with and seems to work very well. Last fall Lynny and I went camping the temp was in the low 40s and we ended up opening a window. btw I used two layers in the roof. good luck, Walt
All that is needed for evil to flourish, is for good men to do nothing.
Walt M
Images: 50
