DestinDave wrote:I had that set also and used it in my radial saw quite a bit.
Are you refering to a radial arm saw? I was wondering if I could use my dado set on my radial arm saw, but didn't see any mention in the instructions.
DestinDave wrote:JunkMan: Yes, you should be able to if the arbor is long enough and the right size (5/8 usually). My dado set is a "stacked" set with two normal blades for the outer cutters and "chipper" blades for the inner cutters and by stacking them you can get a variety of thicknesses. Just pull the blade into the wood SLOWLY and with control. Better yet, make successive passes taking out a little at a time. The blades will "grab" the wood and tend to run towards you - sometimes a scary feeling. Also, keep an eye for knots in the wood - the blades can pull through quickly or worse, tear out the knot and "explode". I used the dado set making 3/4" deep by 3/4" wide passes to cut all the half-lap joints on my floor subframe. No real problems but like I said above - SLOW AND CAREFUL!!!!!
I've never used a wobble dado head on a radial arm - only a table saw so I can't say how they would work.
JunkMan wrote:[quote="Larwyn]I liked that I could see the dado as it was being cut.
Denny Unfried wrote:My biggest complaint with a wobble dado is the bottom of the cut is never flat and smooth like you get with a stacked dado. That could be a strength issue on a glue up when the surfaces aren't making complete contact.
Denny
Denny
