Steve_Cox wrote:Cody Pendant wrote:Cody,
Welcome to the forum...... Please don't make me watch the video and search for the results..... just tell us.........
aggie79 wrote:Where I had good, close tolerance mating surfaces and could apply glue and clamp quickly, I used TB III (for example, in the sandwich construction of my floor and sidewalls).
Where there was less close tolerances and I need some working time, I used PL glue (for example, bending and fastening plywood to roof spars.)
BK One wrote:Looking for some opinions. I'm about ready to glue my skins to my 1x framing. I've got Titebond and PL adhesive. Any preference? I thought the PL would be better. Do we have to worry about any fumes emitted after it's cured? We are in an small space.
The shocking thing about TB III or any other conventional yellow wood glue is the clamping force required for maximum strength.
Rock wrote:The shocking thing about TB III or any other conventional yellow wood glue is the clamping force required for maximum strength. In that article I think they applied over 100 pounds/square inch of joint.
I did use TB III to glue my walls together. For my little 4 X 8 walls I had 600 lbs of concrete blocks on top of the clamping cauls. Guestimating at the surface area of my framing, I'm guessing that I got barely 1 PSI of clamping force. The walls have not fallen apart yet but it's only been on one trip.
If I had vacuum bagged, I would have gotten 14 PSI max - still far short of the recommendation. We would need a giant hydraulic press (Terminator fans out there know what I'm referring to) to get the 100 PSI recommended for max strength. But then again, our walls should never see the kind of stress that they applied in the article.
Eric
