woodworking question
Postby Ageless » Thu Oct 08, 2009 3:20 pm
You really need a table saw!
Or at least one of these:
[url]http://www.instructables.com/id/Convert_a_hand_held_circular_saw_into_a_table_saw/
Ageless
Postby Micro469 » Thu Oct 08, 2009 8:52 pm
My question would be why you would need 2x4's for the floor. I used 1x2's for mine, sandwiched between 3/8" plywood..... Plenty strong. I think you are just adding extra weight.......unless your hauling around an elephant.....
:roll:
John
Micro469
Images: 382
Postby SIXTOTWO » Mon Oct 12, 2009 5:18 pm
We laped our floor joints.
Here is a before photo...
And an after...
Close up...
We used a radial arm saw but it could be done with other such tools.
Hope this helped a little.
Terry and Sue Landis
BUILD THREAD
******Embarassing our kids, just another quality service that we offer!******
SIXTOTWO
Images: 216
Postby toypusher » Mon Oct 12, 2009 6:36 pm
Micro469 wrote:My question would be why you would need 2x4's for the floor. I used 1x2's for mine, sandwiched between 3/8" plywood..... Plenty strong. I think you are just adding extra weight.......unless your hauling around an elephant.....
:roll:
If you are making a sandwich, you should be able to use 3/4" framing and 1/4" on both sides and it will be plenty strong. Put ridgid insulation in the empty spaces as tight as you can get it.
toypusher
Images: 324
1x vs 2x
Postby laoutdoorsman » Tue Oct 13, 2009 4:25 am
mainly only because the selection of 1x material around here sucks...2x is sooo much easier to get , and actually more affordable...
im not building a small tear, so i think id prefer a stronger setup...maybe its not needed...
im not moving forward at all right now...stuck in a rut, seriously contemplating a tear-down/redesign/startover.....plus, it rains every damn day...
i just stumbled across tons of free steel....so, another project has moved to the front burner...lol
those lapjoints look awesome...i dont have the patience to do that...
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
