Has anyone used 3M VHB tape
Postby Gage » Tue Nov 03, 2009 4:13 pm
halfdome, Danny wrote:
If you can find someone in your area that sells screw posts for binding they work great for the hatch.
I've use them with the RV insert molding on 3 teardrops so far without any problems. :D Danny
Where do I start looking for those Denny?
Image Image Image
Gage
Images: 28
Hatch
Postby Chris D » Tue Nov 03, 2009 4:20 pm
Danny,
I have used something like that for fastening euro cabinets together. They would work great on the hatch!!!!! Great Idea. I have also seen someone use t-nuts for the hatch also but I like your Idea better.
What would I ask for.
Thanks Chris D
Chris D
Postby aggie79 » Tue Nov 03, 2009 5:15 pm
Gage wrote:Where do I start looking for those Denny?
I don't know who came up with the names for them, but they are called "sex bolts" or "Chicago bolts".
Postby halfdome, Danny » Tue Nov 03, 2009 6:11 pm
Gage, they are used for making folders with three holes punched like a 3 ring binder. Try office supply stores and if you have a good hardware store other than the Home Depots or Lowes you might find them there. They are available on the Internet too. I get mine locally from http://www.mclendons.com/ . :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Gage » Tue Nov 03, 2009 8:30 pm
Thank you gentlemen. :thumbsup:
Image Image Image
Gage
Images: 28
Postby starleen2 » Tue Nov 03, 2009 8:34 pm
Scrapebooking supply stores usually have em' too. Mrs starleen uses them all the time to bind scapebooks
starleen2
5th Teardrop Club
Postby High Desert » Tue Nov 03, 2009 11:14 pm
and they are sometimes also known as Chicago screws when used on horse tack. They can often be found at feed stores and the like. Online they can be found at horse.com and a few similar sights; here's a example, $2.95 for a 10 pack
http://www.horse.com/Chicago-Screws-(10-Pack)-BPN12.html
with a little looking they can be found in varying lengths too.
Great idea Danny. I've used these for years in other uses but never would have thought of them for this.
Shaun
High Desert
Images: 27
Postby signs » Wed Nov 04, 2009 10:31 pm
VHB is used in the sign industries for many reasons. If you want a single roll, make friends with your local sign shop owner or contact one of the sign supply housed, Fellers.com, signwarehouse.com, N Glantz, Graphic solutions, or search the yellow pages in your area for "sign supplies"
Jay
Yes I spent the last 8 years in the sign business
signs
Postby Trackstriper » Wed Nov 04, 2009 11:32 pm
Jay,
Do you have any comment about how the generic vhb type sign making tapes hold up long term? I have a couple of rolls purchased from a sign supply dealer but the product is not made by 3M. It sounds like most of the trailer manufacturers that use the tape in lieu of mechanical fasteners for attaching aluminum skins probably use 3M brand.
http://www.alumapanel.com/view_product.cfm?step=1&lines_ID=307&name=Alu-%20Tape%20Double%20Sided%20Foam%20Tape
What think you about generic in terms of strength and durability.
Trackstriper
Images: 38
Postby sid » Thu Nov 05, 2009 8:16 am
Gage, this is where I got mine......
http://www.mcmaster.com/#catalog/115/3064/=4dc6w4
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby Wolfgang92025 » Mon Nov 09, 2009 11:31 pm
found another source for VHB tape
http://www.mcmaster.com/#3m-vhb-tape/=4fpzoj
Wolfgang
Wolfgang
Wolfgang92025
Images: 660
Postby Jerry Bleeg » Tue Nov 10, 2009 1:17 am
Sid, do you know which of these screw posts you ordered.
Looks to me that the 1/$' long posts in Aluminum might work best for holding hatch trim on a hatch paneled in 1/8" luan.
Jerry Bleeg
Images: 48
Postby sid » Tue Nov 10, 2009 9:16 am
Jerry Bleeg wrote:Sid, do you know which of these screw posts you ordered.
I tried the aluminum ones first and they seemed to strip out too easy. I switch to the stainless and didn't have any problems, but I don't think mine were 1/4"... I think they were shorter, so that may have caused some of the problem.
sid n side
sid
Images: 194
Postby halfdome, Danny » Tue Nov 10, 2009 10:31 am
I've used the 1/4" aluminum ones ( one layer of 1/8" ply.) and they work great if you don't over torque them.
Once I had to buy longer ones and just ground down the threads to fit.
Stainless would be best but isn't available locally for me.
I goop them up to make a nice seal. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
