Ageless
No nut. You drill a hole the size of the tip and drive them in. The helical cuts threads in the material. In 35 years; never saw one pull out.
Classic Finn
I received some nice samples of the Aluminum and Stainless today in the mail. And majority is 1mm in thickness. Stainless is 0.05.
I was surprised by the fact that they have a nice Black, Maroon, Silver, and Grey. All in all my favorite colors.![]()
teardrop_focus wrote:Carter, that's a gorgeous standie you built; I just looked through your album!Ageless
Mr. Ageless, you, sir, are an INVALUABLE resource! considering your stated background; I cannot thank you enough for your contribution to my teardrop construction plans.
Having said that, would the use of any type of glue or other adhesive be of any benefit? even though you've just said you have never seen one pull out. Thanks again.Classic Finn
Two questions for our Scandinavian Bureau Chief...
One: Is this "silver" you speak of a paint-like color/finish or is it simply the cast of raw aluminum?
Two: Where did you source your samples? Overseas? or a producer near your neck-O-the-wo0dz?
Thanks, Heikki!
Carter wrote:Thanks Chris, the trailer has been fun
I used no adhesive to attach my aluminum. I used a brad nailer along the edges to hold it in place while I was putting on the moldings, doors and windows. It just floats over the plywood other than that. I'm sure there are adhesives that would hold but nothing I could pick up at Ho-De-Po in 2004 that I trusted.
Jim
Finntastic.
Tux wrote:I found a supplier of alu moulds and edgefittings![]()
http://www.duuri.fi/no/index.html and he's well represented here in Scandinavia. He only sells to warehouses and such OR in larger quantities.
I've bought some in the local warehouse and they are good....not as soft as I would want....but hten I'll just use a larger hammer
Classic Finn wrote: Yup a huge hammer will bend them for sure.![]()
And a bit of fire to go with it.
