Kelleyaynn wrote:I've looked at used PC routers on Ebay.
Does anyone know how these models differ? They all seem like they might be more or less the 690 recommended by so many here.
The 690
The 6902
The 690LR
Muggnz wrote:I recommend buying one with a round ( circular ) base. I had one with straight sides, it was a pain to cut around corners. My round base one is easy, as the center is always the same distance from the bit. AND if I do need to cut in a straight line, it has a guide to stop me from going astray...
david
GreatPumpkin wrote:Muggnz wrote:I recommend buying one with a round ( circular ) base. I had one with straight sides, it was a pain to cut around corners. My round base one is easy, as the center is always the same distance from the bit. AND if I do need to cut in a straight line, it has a guide to stop me from going astray...
david
Actually, regardless of the brand/price/quality, you will find that none of them are exactly centered. There is a very slight difference between the center of the bit and the edges. Working with bits that have a guide bearing, you won't notice it. Cutting along a straight edge guide you might notice it if you have a tendency to rotate the router as you cut. Using a guide collar or a dovetail jig, and the "slight" difference will show up even greater. Here's an article that explains it a little more in detail: http://www.newwoodworker.com/cntrguidecolr.html
david
