alright, more like it. Going to polyester resin and paint it.
KIA'S--MIA'S--POW'S--DAV'S--are what our freedom cost us
starleen2 wrote:OK folks - either I did something wrong or you guys are just analysing way too much. Here are some construction picts of the ladybug. What you are looking at is 5mm luan with fiberglass tape only on the seams and then then entire body sealed with polyester resin rolled on in two coats
Finally painted in ENAMEL exterior latex house paint - and it has held up in the Texas summer heat, been in freezing rain - and everything in between. Nothing has delaminated or separated - did not use CPES. I'm sure both of you have many years of fiberglass experience - way more than me ( slim to none) and you can probably give us numerous reason why this will not work - but there she is - explain the anomaly?![]()
doug hodder wrote:For me...I think the real drawback to polyester is the working time. when it goes....it's real unforgiving and goes almost instantly, as opposed to an epoxy, which has a longer window to work with.
angib wrote:doug hodder wrote:For me...I think the real drawback to polyester is the working time. when it goes....it's real unforgiving and goes almost instantly, as opposed to an epoxy, which has a longer window to work with.
This makes me think that you've started on epoxy and then tried polyester.
An experienced polyester user would make exactly the same complaints about epoxy. It's easy to adjust the cure time on polyester to be as long as you want, just by altering the hardener ratio - something not to try with epoxy, where you have to instead buy different speed hardeners.
It's even possible for old hands to take polyester that hasn't gone off, and apply a layer of hot mix (high hardener ratio) resin over the top which then 'kicks' the underlaying layers into curing.
It really is a case of what you're used to, and which horse is right for which course.
Andrew
