Cutting/Trimming Aluminum panels ? ?
Postby Mikey1975 » Fri Mar 05, 2010 9:59 pm
wood bit will work you don't need one for aluminium???
Mikey1975
Images: 23
Postby afreegreek » Fri Mar 05, 2010 10:00 pm
Mikey1975 wrote:You talking crap about FREUD LOL thats what i got :lol:
ya they make good bits but you don't need a $20.00 bit when a $10.00 bit will work just as well. save your Freud for wood because it won't cut as well after you cut metal with it.
afreegreek
Mikey1975 wrote:wood bit will work you don't need one for aluminium???
correct
afreegreek
Postby Mikey1975 » Fri Mar 05, 2010 10:01 pm
ok thanks
Mikey1975
Images: 23
Postby Mike_La » Fri Mar 05, 2010 10:11 pm
Thanks for the info, afreegreek. :thumbsup:
So I'll be looking for a 1/4" shank, 1/2" diameter cut, single or double flute, wood bit. Correct?
Will be making a trip to the hardware store tomorrow.
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
Postby afreegreek » Fri Mar 05, 2010 10:16 pm
Etech wrote:Thanks for the info, afreegreek. :thumbsup:
yup, that's right. the cheapest one too. but you'll probably only find the two flute ones in stock..
afreegreek
Postby afreegreek » Fri Mar 05, 2010 10:19 pm
afreegreek
Postby Ageless » Sat Mar 06, 2010 10:03 pm
BTW, application of parafin to the bit will keep the chips from loading up on thr bit
Ageless
Postby Mike_La » Sun Mar 07, 2010 8:23 pm
I want to thank everyone who replied with advice to my question.
I pulled the RotoZip out of the storage bag today and little did I know, I had a two flute bit in the bit case. In fact there were two. They were both 3/8" bit.
I first trimmed the profile of the .040 aluminum panel(over-sized) using snips, then clamped it to the sidewall. I drilled a 1/2" starting hole and cut out the door opening. The cutting went smooth with the 3/8" bit.
I'll leave the Blue protective film on until I install the doors and edge molding.
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby afreegreek » Sun Mar 07, 2010 9:05 pm
see.. cut like butter didn't it.. :thumbsup:
afreegreek
Postby Mike_La » Sun Mar 07, 2010 9:14 pm
Yes it did.
Like the young-uns say, "That RotoZip is The Bomb".
Mike
Theodore Roosevelt
Mike_La
Images: 71
Postby afreegreek » Sun Mar 07, 2010 10:33 pm
you can do really fine work with a regular bit on aluminum.. this is about aluminum is about 1/16" but I've used plate aluminum up to 3/8" and had good results.. you just need to go slower.
afreegreek
