twist locks to disconnect your camper from the trailer
Postby Conestoga » Wed Mar 10, 2010 5:26 pm
well if you use lengths of pipe as sleeves, and a smaller pipe inside those like a hinge pin. it might be a bear to get loose, though.. think how much fun it is to take a door off its hinges.
pipe hangers, clamps, straps would secure the "sleeve pipe".
i was thinking how cool would it be to just pop legs on the ends of the pipes and tada the camper is standing. then just pull the trailer ahead and away.
Conestoga
Images: 22
Postby Conestoga » Wed Mar 10, 2010 5:31 pm
wow, jnowis sneaked one in there as i was typing.
personally, i think the frame and camper are best when designed as a unibody.
Conestoga
Images: 22
Postby Grid Runner Adventures » Wed Mar 10, 2010 6:04 pm
if the posts and quickrelease pins works though why not so you could have a cargo trailer again?
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby Conestoga » Wed Mar 10, 2010 6:17 pm
hey, i'm with ya.. i'm fond of the idea myself.
try it!
have you seen this one?
http://tnttt.com/viewtopic.php?t=31995
Conestoga
Images: 22
Postby Grid Runner Adventures » Thu Mar 11, 2010 8:24 am
Well I checked with vendors and distributors and they cannot find me any quarter turn fastners long enough to attach a 2x2 framed floor to the trailer so looks like I will have to do my thought of the posts and pins
Postby brewwagon » Mon Mar 15, 2010 3:38 pm
what about something like these? A turning lock lift handle. Maybe put 1 in each corner or 3 on a side.
(stainless wont let me link to image) http://ep.yimg.com/ca/I/yhst-1752524883 ... 94_2624777
ebay/google search for "Stainless Round Turning lock hatch lift handle with key"
I think they also come in with a lock if needed.
It says "Diameter: 2-1/2" Overall Height: 3-1/2" Range of Locking Adjustment: 1-1/4" to 3"."
It would just be a matter of figuring out what that arm swings into/under.
brewwagon
Postby Grid Runner Adventures » Thu Mar 18, 2010 10:06 am
ok its been a couple days of mulling this over,
what if i just put a pipe flange inside the camper bolted to the floor and drill hole, and thread a nice strong water pipe through the pipe flange pointing down i'll have four of these one for each part a 2x4 sidwall holders go into the trailer, then i just put a quickrelease pin through the 2x4 sidewall holder into the frame of the trailer itself..
what do you guys think.. if i do this i should probably weld the 2x4 holders to the trailer instead of keeping them bolted on?
Postby firemaniac » Thu Mar 18, 2010 1:21 pm
If I built something like this for myself, I would
    weld a 1/2 or larger nut to a plate, make 6 to 8 of these assemblies
    mount the plates to the trailer, somewhat inside the wall profile
    drop a bolt with either a fender washer, or larger backing plate through the floor of the cabin and tighten
I considered going this route, but decided against it as to take the cabin on and off of the frame would have created problems like having to make sure my construction could handle the torsion of an uneven lift, and strengthening the lifting points, as well as emptying everything out of the trailer every time I removed it.
Chris
When in doubt, run in circles, scream, and shout!
firemaniac
Postby bobhenry » Thu Mar 18, 2010 2:34 pm
Transit case latch.
Looks like a glorified recessed hasp to me.
Something a little lighter duty ?
