what kind of screws
Postby Boodro » Fri Mar 19, 2010 1:26 pm
Pre drilling holes is a good idea so you don's split your wood. If you do drill & still split it , I would think you are trying to over tighten the screw. Just my thought. Pre drilling makes the screw go in much easier. Good luck! ;) :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
screws
Postby spud233 » Fri Mar 19, 2010 8:24 pm
:D just finished td build.i used a corse drywall screw to apply floor to frame,but placed lots of construction glue via caulk gun pior to screwing.as screws were covered i used same screws for walls and roof along with LOTS of tube glue
spud233
Images: 14
Postby GreatPumpkin » Fri Mar 19, 2010 9:33 pm
synaps3 wrote:
claw73 wrote:I used 1" drywall screws
:o
I wouldn't use any drywall screws -- they'll split wood spars with ease.
On top of that, drywall screws snap very easily when over torqued. :(
Custom Benroy/Grunman/Hybrid...In Progress
2001 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus." GP
GreatPumpkin
Images: 5
Postby claw73 » Mon Mar 22, 2010 11:29 am
Huh, I've never snapped a drywall screw; on the TD so far or on any projects in the passed. However I'm not using too much torque on the TD for sure. And I'm flying through my tubes of Liquid Nails. And I couldn't agree more about predrilling everything. All the screws are on the outside, with interior skins weighted and glued. Since I'm epoxy coating all the outside, the screws won't rust. Or at least if they start to rust the ply is done for already.
While I would have preferred not using drywall screws for aesthetics, they were lest costly and the only thing that I could find locally in 1". I'll let everyone know if I go driving off one day and it flies away :lol:
claw73
Images: 28
Postby cuyeda » Mon Mar 22, 2010 12:52 pm
All this talk about screwing (pardon pun), I started using this set with the insty drive. It really saves time changing out the predrill bit, and the screwdriver.
www.rockler.com
I splurged a bit and acquired this kit. I use a shorter phillips head bit to decrease length of adaptor. Have yet to install any cabinet hinges, but the self piloting drill will come in handy later.
Coupled with a Dewalt impactor/drill takes some of the chore out of building. Otherwise juggling drill guns would work ok, and get a work out at the same time.
Cliff & Vanessa
cuyeda
Postby claw73 » Mon Mar 22, 2010 3:29 pm
Cuyeda, I've worked with those before and they are pretty nice. I stick with the two guns though. Use what I got
claw73
Images: 28
Postby DasBaldGuy » Mon Mar 22, 2010 9:17 pm
claw73 wrote:Huh, I've never snapped a drywall screw; on the TD so far or on any projects in the passed...
I've never snapped a drywall screw head either...I've stripped a few but never snapped one. I use drywall screws for almost all of my build projects (shelves in the garage, bookshelves etc) and have never had one break.
they DO split wood pretty easily so predrilling is a must.
DasBaldGuy
Postby planovet » Tue Mar 23, 2010 8:35 am
Same here. I used drywall screws AND SS screws on my build. Never snapped a drywall screw but I did snap a few SS screws... :x
ImageMark (& Cindi)
planovet
The Cat Man
Postby claw73 » Tue Mar 23, 2010 12:40 pm
Whew! After the initial backlash for using drywall screws I thought I shot myself in the foot. Spent a whole day convincing myself that they were fine but hearing others in the same boat makes me feel a lot better.
claw73
Images: 28
Postby GreatPumpkin » Tue Mar 23, 2010 7:34 pm
claw73 wrote:Whew! After the initial backlash for using drywall screws I thought I shot myself in the foot. Spent a whole day convincing myself that they were fine but hearing others in the same boat makes me feel a lot better.
Sorry if I contributed to your angst over using drywall screws. I use them all the time in many wood projects, but I have snapped the heads off them many times. (It sounds like I'm the only one though.) :oops: Knowing that they have snapped on me in the past, I chose to use wood screws in my teardrop project as I thought they would hold up better.
I guess I'm to strong for my own good. Image ;)
2001 Dodge Ram 1500
2001 Honda XR650R
GreatPumpkin
Images: 5
